JeremyC Gold Cloverleaf
Posted: Wed Jul 29, 2009 3:46 pm Post subject: Buzzing / Humming gearlever in fifth |
In the last 200 miles or so my gearlever has started making a buzzy humming in top gear. If I apply gently pressure to the left it stops.
Please tell me this is a linkage problem not a 'box problem. _________________ '93 Black 33 1.7 16v |
Posted: Wed Jul 29, 2009 4:00 pm Post subject: |
I would say that when you apply pressure and it stops it would be a linkage thing - (mine rattles at high revs and just putting my hand on it stops it) But to be sure I would get someone else to drive whilst you have a good listen. I'd probably remove the gear stick surround and pull off the rubber jobby so any linkage vibrations/noise will be more apparent. |
Posted: Wed Jul 29, 2009 6:14 pm Post subject: |
Mine rattles like that at about 7,500 rpm!
Probably linkage. Probably fall off soon leaving you stranded.
Posted: Wed Jul 29, 2009 7:21 pm Post subject: |
No my knob is firm, if I grip the shaft that stops the buzzing too. _________________ '93 Black 33 1.7 16v |
Posted: Wed Jul 29, 2009 7:47 pm Post subject: |
this is getting worse, knob....buzzing....sounds like a fan of ann summers.lol _________________ PHAT 33 |
Posted: Thu Jul 30, 2009 7:11 am Post subject: |
known problem ; it's the iron bushing on the lever/linkage articulation. You need to renew it and both o-rings that go in its grooves.
i modded mine with a custom turned delrin insert to avoid changing these parts every 200 000 kms. So far so good.
Posted: Thu Aug 13, 2009 12:28 pm Post subject: |
Just my two bits, but renewing the cylindrical rubber bush in the gear linkage cured that problem for me. _________________ Alfa33 QO 1984
Alfa33 1.3i.e. 1994 |
