Brake master cylinder
alfafan
PostPosted: Sun Jan 16, 2011 4:30 pm    Post subject: Brake master cylinder Reply with quote
Do you know of a bigger plug and play brake master cylinder for boxer Alfas?
PostPosted: Sun Jan 16, 2011 11:02 pm    Post subject: Reply with quote
From a 75, Alex would know Smile
AL33NUT
PostPosted: Thu Feb 10, 2011 11:14 am    Post subject: Reply with quote
I second that. I have one installed in my 33. Was a strightforward fit according to my mechanic.
alfafan
PostPosted: Thu Feb 10, 2011 6:22 pm    Post subject: Reply with quote
Yesterday I bought one and it costed me 59 euros.
It is in fact almost the same.
Did you found any improvement fitting the 75īs on the 33?
AL33NUT
PostPosted: Fri Feb 11, 2011 12:45 am    Post subject: Reply with quote
Well I can't give you a straightforward answer I'm afraid. I did a full big brake conversion (Willwood) so I needed the bigger Master Cylinder (MC) to compensate. I never tried it out with the standard 33 setup because my mechanic just went ahead and swapped in the 75 MC because he couldn't bear to leave me with the long pedal travel and compromised brake feel. So in answer to your question - Yes.
alfafan
PostPosted: Fri Feb 11, 2011 10:55 am    Post subject: Reply with quote
It is not a straight forward fit.
It almost...
You have to change one of the brake lines, the one that is below, but it is simple.
I put it on the 33 and because I didnīt have anyone to help me, I couldnīt bleed the circuit.
But even I didnīt bleed the circuit, I went to test the car and it started to brake, and brake, and brake...
Todayīs morning its braking very well.
Better than before...
Latter I will bleed the brakes.
