ad87 Alfa Arna
Posted: Sun Aug 10, 2003 9:31 pm Post subject: The idle mixture screw |
Does anybody know how many tours for the closest position are necessary for a good running of the engine?I don't found a vacuumeter and my exhaust sistem is "piercing" For Dellorto's DRLA on an 1.7 engine(8v). _________________ Please,I need to know the level in the float chamber for the DELLORTO 40DRLA(Alfa 33,1.7).Can I find a Manual to download for the 2' series? |
ad87 it's really me Guest
Posted: Thu Aug 28, 2003 11:16 pm Post subject: |
| You know I use exactly 3.5 turns.It seems OK before i've used 2 turns! but in the firsts gears then I press fully the accelerator it takes 1 second to do nothing and after to run.Any ideas? |
bvolden Alfa Arna
Joined: 15 May 2003 Posts: 8 Location: Trondheim, Norway
Posted: Fri Aug 29, 2003 10:05 pm Post subject: |
| Does anyone know how far out it should be on the 87 1,5 with twin webber 32s? Mine is very thirsty and I know something is fishy... |
Toad Alfasud
Posted: Sat Sep 06, 2003 10:12 am Post subject: |
for a vacum meter try www.carbtune.com
I've one of these & have used it to great effect on twin carb boxer's & 16ver's. _________________ Shift for Brains |
Posted: Sat Sep 06, 2003 11:55 am Post subject: |
For excessive thirst I would suspect float levels. This would show up with a slowing of the idle,particularlywhen sitting at the lights. The Dellortos are prone to this with their plastic floats. You can usually see this with the aircleaner off. If the level is excessively high, the carbs will dribble out the rear mains on idle.
Regards Eddie |
