Alfa_33_Veloce Alfa Arna
Posted: Tue Aug 26, 2003 7:47 pm Post subject: Tachometer not working |
I've just brought an '88 alfa 33 1.5ti veloce - my first alfa romeo. I brought it knowing there are a few minor things wrong with it. Most I have managed to solve but with the little knowlage i have i still cannot get the rev counter to work. Could anyone help me out?
One last thing could anyone tell me what the ''ti'' stands for thanks a lot. _________________ ** alfa 33 Veloce ** |
Posted: Tue Aug 26, 2003 8:08 pm Post subject: Re: Tachometer not working |
[quote="Alfa_33_Veloce"]I've just brought an '88 alfa 33 1.5ti veloce - my first alfa romeo.
Good man joining the chap's
the rev counter work's off the coil,i think it's the white wire on the coil,check that. all the best john _________________ WODA WE NEED? MORE POWER!!
Posted: Tue Aug 26, 2003 10:04 pm Post subject: |
Hi from Greece,
Welcome to the alfist team of the legendary 33 model!!!
TI stands for Tourismo Internazionale. The same as GT.
Basically it means a more equipped car including various elements like instrument panels , diagnostic readings, a more sporty look including rims, spoilers etc.
Please feel free to ask anything that you may encounter. _________________ Thanassis Gritsopoulos
Posted: Tue Aug 26, 2003 10:58 pm Post subject: |
HI VELOCE
Check the plug that joins the main loom to the dash loom. It`s near the brake master cyl. Aflat black plug seperate from the main wiring. The cable is shielded like an aerial so it doesn`t pick up stray signals. They often give problems at this connection.
Good luck Eddie |
Posted: Wed Aug 27, 2003 5:40 pm Post subject: |
Thanks for your replies they have been really helpfull. _________________ ** alfa 33 Veloce ** |
Posted: Sat Aug 30, 2003 8:47 pm Post subject: |
Ive checked all the leads and cant find the problem.
could it be somthing wrong behind the dash? I heard it was an awkward job taking the dashboard off, so i didnt really want to try. _________________ ** alfa 33 Veloce ** |
Gary UK Alfa Sprint
Posted: Sat Aug 30, 2003 10:56 pm Post subject: |
No, taking the speedo console off on the 33 is easy, just a couple of screws. |
Posted: Sat Aug 30, 2003 11:37 pm Post subject: |
You need access to a continuity tester (a lot of multi meters have this facility) and check each segment of the loom right up to the tacho itself. One of my cars had a wire soldered between the point where the loom enters the back of the dash and the tacho unit itself, so there must have been a break in the printed circuit. A continuity tester would help you find such a problem. Also you can check for circuit across that plug I mentioned before.
Good luck Eddie |
