Brit01 Gold Cloverleaf
Posted: Fri Aug 17, 2012 7:29 pm Post subject: MSD 6A system arrived! |
Purchased a really nice NOS vintage MSD 6A ignition module.
A new SS Blaster coil is on it's way (currently this part is stuck in a 1 month postal strike pile!!!!).
Anyway the module works just fine with my Bosch coil for now.
Just got to find a suitable place to mount it and wire it up permanently.
[url]
Uploaded with ImageShack.us[/url] _________________ S2 33 1988 1.7 QV
Bobkelso Alfa Sprint
Posted: Sat Aug 18, 2012 2:57 pm Post subject: |
Hi Brit
Nice design, perfect for a more than 20 years old car..
and I'm really curious about how car run with it. _________________ Alfa 33 |
Posted: Wed Aug 22, 2012 9:54 pm Post subject: |
curious me too, was about to install it at work then I got blocked carbs this week so car is sitting in the garage unable to start!!
Also one of the cv boots if leaking grease. another thing to fix quickly.
Hopefully get the new pump on tonight to get the car to work tomorrow.
Then lunch break I'll install the MSD this or next week. _________________ S2 33 1988 1.7 QV
Posted: Thu Aug 23, 2012 5:21 pm Post subject: |
All wired up in 30 minutes! Very neatly.
Started up and idled really nicely. I noticed more water and less smoke was coming from the exhaust which is a good sign of clean combustion.
The note of the engine sounded crisper and responded very very well to blips on the throttle.
Haven't tested it on the road yet but that will happen later today. _________________ S2 33 1988 1.7 QV
Posted: Mon Aug 27, 2012 6:04 pm Post subject: |
still running fine after 4 days of testing. Nothing melted or exploded!.
But i think my 60 idle jets are a bit on the rich side.
Got black soot shooting out of my tailpipe!!
I will go back down to 55's.
I hope the stronger spark from the MSD will help the hesitation I had with the leaner jets. _________________ S2 33 1988 1.7 QV
Posted: Mon Aug 27, 2012 7:39 pm Post subject: |
What's the bet that you will end up with standard jets, now fueling is normal?
Mind you you have better filtering  _________________ x2 33 16v
Posted: Mon Aug 27, 2012 7:43 pm Post subject: |
BigAl,
You may well be right. Now I have a good powerful fuel pump and strong spark. Won't have any issues with floats dropping too low etc
mmm...what idles shall I try first??
Maybe the 55's.
Dellorto always said the 52's were on the lean side for emission tests. _________________ S2 33 1988 1.7 QV
Posted: Wed Aug 29, 2012 1:47 pm Post subject: |
| BigAl wrote: |
Mind you you have better filtering  |
55's worked well. I won't go leaner as I felt just a tiny bit of hesitation. (probably due to the trumpets and new K&N style filters).
Had to do some major balancing again this morning, was out of whack! Sitting idling at the lights it was lumpy which I hate.
Was trying to find the sweet spot this morning. Lets see on the way home if they are smoother. _________________ S2 33 1988 1.7 QV
Posted: Wed Aug 29, 2012 2:06 pm Post subject: |
Out of interest, what do you use to balance your carbs? I used to try by ear and a listening tube, but I never got the knack, so I used to get them tuned.
I use a Synchrometer now on my TB's  _________________ x2 33 16v
Posted: Wed Aug 29, 2012 2:28 pm Post subject: |
| BigAl wrote: |
I use a Synchrometer now on my TB's  |
I've got 2 needle vacuum gauges, I use a small aquarium air pump valve to dampen the fluctuations and connect them to the vacuum outlets at the base of the carbs. Does the job ok but a bit fiddly.
Also by ear, carefully leaning each one out until the revs slow then back them off to smooth each cylinder out. _________________ S2 33 1988 1.7 QV
Posted: Wed Aug 29, 2012 2:45 pm Post subject: |
Thought about the Gunson yes but same principle really, connect all the tubes and you need the dampers also I believe.
But all four at the same time yes would be more useful.
But the synchronizer you have you need to go back and forth no?
When you adjust one it can alter another.
Even if you have all 4 in sync you still need the get the mixture right, that can only be done by listening and fiddling with the mixture screws.
(unless you have 4 colourtune plugs)
Either way still takes practice and patience. _________________ S2 33 1988 1.7 QV
Posted: Wed Aug 29, 2012 6:02 pm Post subject: |
Anti-theft switch installed! :cheese:
Anyone who tries to start the engine will have no spark (secret switch hidden)!! And they'll never know what's wrong as MSD is not known here. :cheese: _________________ S2 33 1988 1.7 QV
Posted: Mon Sep 03, 2012 7:55 pm Post subject: |
I'm surprised but I think the MSD has affected the timing somewhat.
I need to retard it more. Hesitates to crank on the first turning of the key.
Pings a little under very hard acceleration still.
Timing at 4500 rpm is on the mark at 34 degrees but TDC is just about less than 7 degrees.
More retard I guess.
Oil temps stable but water tends to heat up quickly when idling after a long run at higher speeds. _________________ S2 33 1988 1.7 QV
Posted: Thu Sep 06, 2012 3:46 pm Post subject: |
Thinking now that maybe the new K&N style filters could be causing the detonation.
These are going to allow more air in.
Under WOT could the mains be too lean? (currently 145 mains).
Does anyone else run these filters and what jets do you use?
Otherwise I need to do some swapping around, comparing the set ups.
Filters on/off, MSD on/off.
Where will I find more time away from the misses?  _________________ S2 33 1988 1.7 QV
Posted: Sat Sep 08, 2012 11:54 pm Post subject: |
Anyway I gave a good suirt of wd40 and some oil around the shaft to drip down and some down the sides to reach the weights(hopefully).
Rotor springs feel ok.
Sucked on the vacuum while idling and it did move. Not much but some. (How much should it move? Maybe it's weak)
Plugs were a light brown. changed to 9 plugs.
Advanced it to almost 8 degrees. tested it at full revs and it didn't exceed the 34 degrees.
had a spin around and did't hear ant pinging. Was a tiny bit lumpy, bit lean I think on the idles but I only have 55's and 60s. 60's were too rich. Think I need to buy some 57's or 58's from Italy or Dellorto UK.
idled cooler though .
but it needs a good hard drive to test fully.
There is a circlip around the top of the shaft. If I remove this will the top timing plate come off and then I'm able to access the weights/springs? _________________ S2 33 1988 1.7 QV
Posted: Mon Sep 10, 2012 1:26 pm Post subject: |
Nope still getting detonation!!!
Plugs showed no signs of lean mixtures.
I will disconnect the unit and compare it with stock ignition next.
Maybe the timing is out on the MSD or it's not working well with the stock coil or something.
Could of course be the dizzy weights/springs but this is a process of elimination so one thing at a time. _________________ S2 33 1988 1.7 QV
Posted: Sun Sep 16, 2012 1:50 pm Post subject: |
Ok further testing done.
1) original airbox on and stock ignition - smooth progression and no pinging
2) original airbox on and MSD running - hesitation between 2-3000 rpm and a small amount of pinging under fast acceleration. But smoother idling and more power despite the hesitation.
MSD have already told me more than once the 6A will cause a lean condition and is the most likely cause of the pinging.
So a slightly larger idle jet maybe needed. _________________ S2 33 1988 1.7 QV
Posted: Tue Sep 25, 2012 9:38 pm Post subject: |
BP8ES plugs put in.
Projected plugs may help avoid the small amount of detonation I'm experiencing as suggested by my local mechanic.
He tested it, inspected the dizzy and said everything was spot on and the detonation was so very slight.
The P plugs may well just clear this.
Gap extended to 1.1mm. Felt good but didn't have enough time to test it fully.
Also suggested by a member on alfaowner was to add a specific amount of acetone to the fuel to improve it's quality _________________ S2 33 1988 1.7 QV
Posted: Wed Sep 26, 2012 12:25 am Post subject: |
Hi Brit, just about..someone says that varying the plug gap
also the ignition timing can vary a little (more gap=more retard)
but I don't know if the effect is considerable or very small,
expecially with your upgraded ignition module,
so probably a new check of the timing isn't necessary..
Ps.: this man thinks nitroglycerin pills
are the solution for a better fuel quality ' '
http://www.youtube.com/watch?v=jW61Qiko4sg _________________ Alfa 33 |
mg907 Alfasud
Posted: Wed Sep 26, 2012 9:17 am Post subject: |
I've heard that projected electrode plugs like BP8ES should not be used because their spark is too close to the cylinder top surface.
Is it definitely true?
I'm currently using BR8ES, they work really fine both with gasoline and LPG.
Mario |
Posted: Wed Sep 26, 2012 2:07 pm Post subject: |
| Quote: |
Is it definitely true? |
I've heard this for some alfa engines but not the boxer in particular. The boxer 1.7 has domed/concave pistons and the plug is quite recessed.
I know the Golden Lodge were designed with this in mind, keeping the spark away from the piston but maybe more for the arna/smaller boxers like the sud.
But if it helps to avoid detonation I think the pros outweigh the cons.
I'm also in discussion about adding small amount of acetone to the petrol.
The petrol here is imported from Brazil and is of awful quality.
You have much better petrol in Europe remember. _________________ S2 33 1988 1.7 QV
mg907 Alfasud
Posted: Thu Sep 27, 2012 10:45 am Post subject: |
Hi Brit,
an octane number list follows (basic font wikipedia):
hexadecane < -30
n-octane -10
n-heptane 0
diesel 15–25
2-metileptano 23
n-hexane 25
2-metylhexane 44
Hydrogen 130
n-heptane 60
n-penthane 62
1-pentene 84
1-butanole 87 ---> can be produced from biomass
n-butane 91 ---> LPG component
cyclohexane 97
E10 98 ---> 10% ethanol and 90% gasoline
isooctane 100
benzene 101
propane 103 ---> LPG component
E85 105 ---> 85% ethanol and 15% gasoline
CNG 107
LPG 108
heptane 108
methanol 113
toluene 114 ---> component of lacquer thinner
ethanol 116 ---> ethylic alcohol
xylene 117 ---> component of lacquer thinner
I do not know if acetone can rise the octane number and or if it could get the pollution level worse.
But just a question. Isn't the E10 fuel available in your country? In many places, such as Brazil, Argentina as well in
some European countries you can find it.
I think it could resolve your pinging problems.
I have to say that may 33 pings a little when accelerating in 4 or 5 gear, but it does so only when running with gasoline,
with LPG that has an higher octane ratio the ping disappear at all.
Mario |
Posted: Thu Sep 27, 2012 1:58 pm Post subject: |
| mg907 wrote: |
Hi Brit,
hexadecane < -30
n-octane -10
n-heptane 0
diesel 15–25
2-metileptano 23
n-hexane 25
2-metylhexane 44
Hydrogen 130
n-heptane 60
n-penthane 62
1-pentene 84
cyclohexane 97
isooctane 100
benzene 101
CNG 107
LPG 108
heptane 108
methanol 113
Mario |
Yes we don't have any choice.
2 types of petrol.
Super 95 and Premium 97.
Both have 10% ethanol but the octane level is much lower than indicated!
3 years ago it was so much better. Now god knows what Brazil are putting in it. I think they are watering it down!!! _________________ S2 33 1988 1.7 QV
