Brit01 Gold Cloverleaf
Posted: Tue Aug 06, 2013 12:37 am Post subject: Another part failing! ! |
When one thing goes it is always followed by another issue.
Got a bearing noise around the water pump or left timing belt pulley tensioner.
Only when cold though.
Will take off the pump pulley and start the engine to see if it's the pump orvbelt tensioner.
Looking at the dayco timing kit. _________________ S2 33 1988 1.7 QV
Posted: Tue Aug 06, 2013 7:26 pm Post subject: |
Yep. I have the same problem at the moment.
My grating noise is coming from the other bank (16v) so not a water pump issue. Haven't yet determined which pulley has gone but it's on the jobs to do list...sooner rather than later! |
Posted: Tue Aug 06, 2013 7:33 pm Post subject: |
| lee16v wrote: |
like a grating noise isn't it?
Just bought the Gates timing kit.
Looking for a pump now also.
Dolz are cheap.
Valeo or Mapco also on ebay.
Anyone heard of Dolz?
http://www.ebay.co.uk/itm/271253279559 _________________ S2 33 1988 1.7 QV
Posted: Tue Aug 06, 2013 10:30 pm Post subject: |
thanks.
Maybe Valeo is a better choice then. just a few pounds more.
Valeo is a choice for alfa with some parts.
Original alfa pump close to here in Buenos Aires is 100USD + shipping/taxes.
Maybe I can get one for a 145/146 or even Nissan Cherry/Sunny N12. _________________ S2 33 1988 1.7 QV
Posted: Wed Aug 07, 2013 5:40 am Post subject: |
As far as I know the pump is the same for all Alfa boxer engines.
The timing belts are 98 teeth for mecanical tappets and 100 for hydraulic. _________________ Alfa33 QO 1984
Alfa33 1.3i.e. 1994 |
Posted: Wed Aug 07, 2013 5:14 pm Post subject: |
Bought myself a Valeo water pump.
Well known name so hope it should be good.
very good deal on Mister Auto. free p&p also.
Now just got to get it to Uruguay!!
Anyone visiting next week?? jaja _________________ S2 33 1988 1.7 QV
Posted: Mon Sep 23, 2013 4:22 pm Post subject: |
New water pump installed along with tensioners and belts.
Old pump looked ok but had a plastic impeller.
I did notice a difference in water temp.
Stays a little cooler and when idling stuck in traffic the temp is more stable. It does not rise as fast as it did before.
So new pump is shifting more water apparently.
[img] [/img] _________________ S2 33 1988 1.7 QV
