1.7ie Rear Shocks
Goto page 1, 2  Next
Blueskev
PostPosted: Thu Aug 15, 2013 9:12 pm    Post subject: 1.7ie Rear Shocks Reply with quote
So, I bought some new rear shocks because one of the old ones is leaking, it looks like you have to take the springs out to replace the shocks or am I missing something?
After narrowly avoiding a serious eye injury when changing Multipla springs, I don't want to take them out if I don't have to!
Kev.
PostPosted: Fri Aug 16, 2013 12:07 am    Post subject: Reply with quote
No need to compress springs on rear. Undo top mount on strut and jack the car up while letting the axle hang (spring should now be loose), undo bottom nut to strut and remove spring and strut together.
ZeNiTh-PbArM
PostPosted: Fri Aug 16, 2013 1:11 pm    Post subject: Reply with quote
You'll need to disconnect the brake pipes to get enough slack for lowering the rear axle - some bleeding required after the job is completed!
zp
PostPosted: Fri Aug 16, 2013 4:30 pm    Post subject: Reply with quote
I did the job without disconnecting brake lines, but it would be easier doing so as ZP says.
Blueskev
PostPosted: Fri Aug 16, 2013 10:00 pm    Post subject: Reply with quote
Great Smile thanks chaps.
PostPosted: Mon Aug 19, 2013 9:11 pm    Post subject: Reply with quote
If you can, avoid touching the pipes and having to bleed them as the rear compensator can get air in it and be a PITA to bleed Smile
Blueskev
PostPosted: Fri Aug 23, 2013 9:40 pm    Post subject: Reply with quote
Thanks Al, I hate bleeding brakes so I was hoping to get away without disturbing the pipes Very Happy
Kev
PostPosted: Sun Aug 25, 2013 8:06 pm    Post subject: Reply with quote
Just make sure when you 'drop' the axle you don't put any strain on the flexi pipes.
Ian M
PostPosted: Sun Aug 25, 2013 10:04 pm    Post subject: Reply with quote
Lee your a genius
I want to have your baby's
Presntly own
Red Abarth 500c
The Wombat
PostPosted: Sun Aug 25, 2013 10:08 pm    Post subject: Reply with quote
I did the rear shocks on the green SW a few weeks back. No problem with the flexis. Did one side at a time so easy to manage not straining them
Drivers:
- Green Fiat 20VT Coupe
- Champagne 155 V6
- Winter Freelander
- Mrs Wombats Freelander
Projects:
- Various 33s
- Some 155s
Hibernating for 2015
- 75 3.0 Cloverleaf
- 155 Q4 Winny
- Red 33 16v
PostPosted: Mon Aug 26, 2013 10:40 pm    Post subject: Reply with quote
Ian M wrote:
Lee your a genius
I gave you them years ago...................
Blueskev
PostPosted: Wed Oct 02, 2013 9:30 pm    Post subject: Reply with quote
Job done Smile did one side at a time lowering the axle, not a bad job to especially as all the nuts came undone easily Smile Shame the jacking point went crunch when I tried to do the near side though!!
PostPosted: Thu Oct 03, 2013 8:22 pm    Post subject: Reply with quote
Nice one......now crack out that welder!
Blueskev
PostPosted: Thu Oct 03, 2013 11:06 pm    Post subject: Reply with quote
If only! Hoping my local garage can do it, the jobs are mounting up faster than I can tackle them! (and I haven't got a welder or the skills)
johnboy
PostPosted: Fri Oct 04, 2013 6:48 am    Post subject: Reply with quote
Morning
Where in kent are you Kev ? Plus welding not that hard, just take your time and if it looks crap grind it down for a cleaner look Wink
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
Blueskev
PostPosted: Fri Oct 04, 2013 10:02 pm    Post subject: Reply with quote
johnboy wrote:
Morning
Hi Johnboy, Im in Maidstone, couldn't be much further away and still be in kent lol. I made the mistake of buying a gasless mig years ago, Ive used it in the past, but its way too fierce for car bodywork. Im toying with the idea of getting a new conventional one, especially as Ive got the spare wheel well to do as well. Hopefully top spares dude Alex is getting me a replacement well Smile
I have been considering advertising the car on here because I can't see me having the time to get on top of the job list, but Im not giving up just yet!
Kev.
PostPosted: Fri Oct 04, 2013 10:30 pm    Post subject: Reply with quote
Blueskev wrote:
top spares dude Alex.
I like it. Alex's new handle Laughing
johnboy
PostPosted: Sat Oct 05, 2013 1:47 pm    Post subject: Reply with quote
Hi KEV
Maidstone ah had some top nights out there, girls very friendly Wink
As for the spare wheel well you could always chop it out and put a plate over it! That's what I will be doing when I ever start my resto Rolling Eyes but mine will be alloy riveted in for a bit of weight saving Wink
Get yourself a welder and get playing Cool
Ian M
PostPosted: Sat Oct 05, 2013 6:37 pm    Post subject: Reply with quote
[quote="johnboy"That's what I will be doing when I ever start my resto Rolling EyesCool[/quote]
Hmmmmmm
If that sees the road before I retire it will have to rank up there with the second coming Wink
Sorry john couldn't resist Wink
Your turn Lee
Presntly own
Red Abarth 500c
Edward
PostPosted: Sat Oct 05, 2013 6:42 pm    Post subject: Reply with quote
I'm not a long way from chopping out the spare wheel well in my car. I am again going to do what I did before in the track car, is cut the wheel well out and replace with a riveted aluminium floor. Trying to save weight and make space again. Much as johnboy was describing.
You would be welcome to the wheel well if you wanted it, assuming Alex doesn't find you one in the meantime.
E.
The faster the better.
PostPosted: Sat Oct 05, 2013 8:32 pm    Post subject: Reply with quote
John, you've only got six months Laughing
Blueskev
PostPosted: Sat Oct 05, 2013 9:43 pm    Post subject: Reply with quote
E.
Great, thanks Edward Smile
Kev.
johnboy
PostPosted: Sat Oct 05, 2013 11:39 pm    Post subject: Reply with quote
Evil you lot Crying or Very sad
Well the concrete was poured for the garage base today, the garage build has started Cool
So lee how's the resto going on your 33 Razz
johnboy
PostPosted: Sat Oct 05, 2013 11:42 pm    Post subject: Reply with quote
Here's the proof
PostPosted: Sun Oct 06, 2013 8:22 am    Post subject: Reply with quote
Looks like it's going to be a biggun John. Reckon you could fit mine in as well. Laughing
Goto page 1, 2  Next
Page 1 of 2
