Posted: Sun Mar 14, 2004 4:15 am Post subject: 16V - vacuum pressure |
Any ideas on what the pressure of the vacuum line to the fuel pressure regulator should be? It feels like there is almost no vaccum at idle.
I am guessing that the low vaccum is the likely cause of the car running very rich (car will not run at all after 1/2 hour due to fouling of plugs).
The cylinder compressions are OK and there don't appear to be any leaks from the vaccum lines.
Any ideas?
Robert. |
Marcin Alfa Sprint
Posted: Mon Mar 15, 2004 8:41 am Post subject: |
Does your car have a lambda probe? Faulty probe will also cause the car to run rich.
Marcin |
Posted: Mon Mar 15, 2004 8:34 pm Post subject: |
Hi Marcin,
Thanks for the reply. Not sure if the car has a lambda probe or not. Where should I look?
I have checked the injection fault codes and there are no errors.
Robert |
BILL Alfa Sprint
Posted: Mon Mar 15, 2004 8:49 pm Post subject: |
| Anonymous wrote: |
Hi Marcin,
Robert |
If you have a cat convertor and use unleaded fuel you must have a lambda probe.Or look under the car if a cable is connected to the exhaust.Hope i helped!! |
