gearbox circlip
Goto page 1, 2  Next
PostPosted: Sun Dec 04, 2011 12:47 pm    Post subject: gearbox circlip Reply with quote
My gearbox circlip fell off, I have lost my spare, anyone got one for sale?
http://alfaimola.free.fr/technique/transmission/commande/index.html
I need 6,7,8 & 9
PostPosted: Mon Dec 05, 2011 5:51 pm    Post subject: Reply with quote
I found my spare kit
I still want spares for when it happens again
JeremyC
PostPosted: Mon Dec 05, 2011 6:41 pm    Post subject: Reply with quote
Do the bolt conversion, you won't look back!
'93 Black 33 1.7 16v
PostPosted: Mon Dec 05, 2011 10:04 pm    Post subject: Reply with quote
I may not need to as I will be fitting a 1.3 sud box soon Smile
JeremyC
PostPosted: Mon Dec 05, 2011 11:27 pm    Post subject: Reply with quote
Is the linkage different?
PostPosted: Mon Dec 05, 2011 11:32 pm    Post subject: Reply with quote
Think so, put it this way when we fitted my tail part of the gear box to the sud box, the angle of the selector rod and size was different I will take some measurements tomorrow in prep for when it is fitted.
JeremyC
PostPosted: Tue Dec 06, 2011 10:57 am    Post subject: Reply with quote
Don't forget to put a blob of cold porridge somewhere in the linkage to achieve that series three gearshift precision.
PostPosted: Tue Dec 06, 2011 12:24 pm    Post subject: Reply with quote
lol Smile
Bobkelso
PostPosted: Tue Dec 06, 2011 11:08 pm    Post subject: Reply with quote
I have a question on the circlip..
I was not able to put both the clip
(number 7 in the picture you
posted from alfaimolafree site)
and the other clip (number 6 in the picture),
it seam to me that there is enough space
only for one..
Are they alternative? Or somebody was able
to put them (number 6 and 7) togheter?
I tried to use only clip number 7
and it doesn't resist a simple test of 'strong' gear shift ,
so I put the number 6 and is two years that is still there..
Actually I have another kit on the car for emergency,
(arrived to me thank to alfa-restoration site)
and a leverage modified with the bolt ready
to mount next time I will do some maintenance..
but still I don't understand exactly
how both clips are to be used..
JeremyC
PostPosted: Tue Dec 06, 2011 11:39 pm    Post subject: Reply with quote
No, I was not able to install both clips either (the slot was not wide enough to accomodate both) and effectively they do the same thing. There are, however, those on this forum who have!
The slot on my linkage rod had worn shoulders such that they were more chamfered than square and I think this was contributing to my occasional clip loss.
Until I converted to a bolt I carried several spares and wired the one in use in place.
PostPosted: Tue Dec 06, 2011 11:43 pm    Post subject: Reply with quote
I wasn't able to install both either.
I think Bobbber said he managed to get both on. I have put the little c clip on instead of the larger one. and will keep the larger one in the car just incase.
As you say, the groove seems only large enough for one thing, the larger one's center it too big for the main shaft I think.
Bobkelso
PostPosted: Wed Dec 07, 2011 12:23 am    Post subject: Reply with quote
Ok, this is good to know,
because it was two years!! Two years!! that I was thinking
I was someway stupid as I was not able to put on the two little clips
that Alfa-Fiat put togheter in the picture you posted that came from
the Eper manual of spares !!!!!!!!!!! 'Confused'
Damned Eper..
Now yes, I can sleep again 'Very Happy'
PostPosted: Wed Dec 07, 2011 2:22 am    Post subject: Reply with quote
I was in the same boat, but this time I trying the smaller of the clips, seems a lot tighter, if yours has lasted 2 years then I don't think I have to worry Smile
Bobkelso
PostPosted: Wed Dec 07, 2011 12:19 pm    Post subject: Reply with quote
In my case it was the small c-clip that dosn't last the time of a test,
(with the car stopped in the garage I tried to change gear quite strong).
It was the bigger and strange one clip that last untill now.
I think it depends which is best on the 'worn shoulders'
different on each car, so a test is necessary.
I see is also important the combination of rubber and metal discs
(sorry my english) you put before,
if they are quite tight mounted vertically and also orizontally
the clip works "in plane" and is more difficult it fail.
PostPosted: Wed Dec 07, 2011 1:04 pm    Post subject: Reply with quote
Oh great lol, well I have the larger on spare in my car for when it fails. It does seem way tighter than the other type, which is loose.
PostPosted: Wed Dec 07, 2011 8:55 pm    Post subject: Reply with quote
does anyone know the thickness of the rubber washer?
Bobkelso
PostPosted: Sat Dec 10, 2011 2:46 pm    Post subject: Reply with quote
Hi, today I recall to see my kit in the auto,
the rubber washer is 1,5 mm thick.
When I mounted the big clip last time
I put the rubber washer with a combination of 2 metal
washers of various thickness, to have a quite strong
(but not excessively) assembly, with no play,
so the axe remain more aligned vertically
and the forces on the surface of the clip
work more uniformly on all the sides 'Shocked'
PostPosted: Sat Dec 10, 2011 4:17 pm    Post subject: Reply with quote
Thanks,
I have 2 rubber washers there and there is still a gap.
The rubber bush that is in the tube has been pinched at the top and a part has been worn away. I turned mine around but there is still play.
When I can I will replace the rubber bush with a nylon tube.
JeremyC
PostPosted: Sat Dec 10, 2011 11:38 pm    Post subject: Reply with quote
Mangoletsi still have the tube bush (they did when I ordered one in the last coupe of years anyway).
PostPosted: Sat Dec 10, 2011 11:49 pm    Post subject: Reply with quote
Thanks,
I think replacing it would be futile, looks to be a flawed design.
PostPosted: Mon Dec 12, 2011 1:58 pm    Post subject: Reply with quote
Look what I got in the post today
Now guess who from, sender not allowed to guess
PostPosted: Mon Dec 12, 2011 4:09 pm    Post subject: Reply with quote
Father Christmas?
PostPosted: Mon Dec 12, 2011 4:52 pm    Post subject: Reply with quote
hoho ho Smile
eagle3
PostPosted: Mon Dec 12, 2011 6:54 pm    Post subject: Reply with quote
I got mine from Gritsop who could still get them in Greece at the time(about 3-4 years ago). I haven't needed them yet but it's in the glovebox in case.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
JeremyC
PostPosted: Tue Dec 13, 2011 11:47 am    Post subject: Reply with quote
Father Alex?
Father Paul?
Father Just Suds?
Father Mangoletsi?
Goto page 1, 2  Next
Page 1 of 2
