Fitting Alloys from the 145/6
Bellamachinna
PostPosted: Wed Nov 23, 2005 4:06 pm    Post subject: Fitting Alloys from the 145/6 Reply with quote
Hi all...
I was wondering, if the alloys, from the 145/6 Junior would fit in my 33 16v...
That`s almost impossible to get decent tyres in 185/60 R14 (with sporty characteristics), and in 15`, the choice is bigger...
Do anyone knows, if they will fit, or do i need anything else...???
Will i be able to use the same studs???
Any help will be apprecieted
P:Camilo
PostPosted: Wed Nov 23, 2005 11:58 pm    Post subject: Reply with quote
I have Yokahama A539 tyres on the P4 in 185/60 14 sizes. Work OK.
Think you can use 145/6 alloys, but you will need spacers to get the offset correct and also enlarge the size of the centre hole in the wheel slightly. (only by 1mm or so).
PostPosted: Thu Nov 24, 2005 1:45 am    Post subject: Reply with quote
There is a wonderful blue series 3 33 usually parked in the street next to mine wearing those exact 145/6 alloys.
I drool everytime I walk by it!
Bellamachinna
PostPosted: Thu Nov 24, 2005 4:21 pm    Post subject: Reply with quote
Those tyres, are no longer for sale in Portugal...
As well as my current tyres...Bridgestone Potenza RE720.
Everywere i look for them, they tell me that the 185/60R14 size is no longer in production, and when the stock is over, i`ll be forced to change to other tyre/brand... Sad
All i´m left with, are those "ENERGY" tyres, that are not up to the task of putting up with the type of cornering that i`m used to!!! Shocked
I am a complete ignorant, in technical details about the wheels. Can you be more specific?
What is "offset"??? Embarassed
If i need spacers, how "big" should they be?? (big=Thickness)
Also, i presume that if i need spacers, i will need bigger wheel studs... Rolling Eyes
Thanks in advance
P.Camilo
tvatavuk
PostPosted: Thu Nov 24, 2005 7:31 pm    Post subject: Reply with quote
This is offset Smile
http://www.driverstechnology.co.uk/wheel-offset.htm
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101
Can you find GoodYear F1?
Big= few mm 3-4 were on Lucas Alfa (author of AR33 disc list)
Usually you do need longer bolts but it all depends on how thick spacer is and how are bolts you have right now.
Tino Vatavuk
PostPosted: Fri Nov 25, 2005 12:48 am    Post subject: Reply with quote
Offset is the distance between the mid point of the wheel (width wise) and the mounting face of the wheel.
Table of offsets here:-
http://www.alfa-pages.co.uk/offsets.htm
Seems most 145/6 wheels would only need a fairly small spacer, but using them from a Cloverleaf / TI would need fairly substantial spacers.
Bellamachinna
PostPosted: Fri Nov 25, 2005 4:38 pm    Post subject: Reply with quote
Hi...Very Happy
Thanks, for the replies...Now, i understand what is "offset"...
However, i always presumed that 145/6 wheels were "caried over" from the 33.
But, according to the list, the Alfa 145/146 1.4/1.6/1.7 16V have a 43 mm, but the 33, all have 39 mm...
The alloys, that i was considering, are presumably. from the 50mm type Confused
Is there any marking in the alloys, were i can confirm this, or i have to measure one??
Thanks for your time
P.Camilo
PostPosted: Sun Nov 27, 2005 8:32 pm    Post subject: Reply with quote
Thanks in advance
P.Camilo
Camillo,
You can also use 185/65R14 tyres. The only differents is that when you think you´re driving 100 km/h your driving 104 km/h.
Or you can order tyres on-line... Th Dutch shop had 185/60R14. Other shops also!
http://ssl.delti.com/cgi-bin/banden-partner.pl?ID=google
Hope this will help
PostPosted: Mon Nov 28, 2005 11:56 pm    Post subject: Reply with quote
Don't think they are marked. Think you will have to measure them.
We bought some A539s about a month ago in the UK.
Bellamachinna
PostPosted: Tue Nov 29, 2005 4:13 pm    Post subject: Reply with quote
Hi Very Happy
Thanks again for your replies... Very Happy
Unfortunatly, i can`t. The IPO (Portuguese MOT), doesn´t allow changes in tyres sizes...
To change tyre sizes, you have to get a letter, from your`s car main representative, stating that the car characteristics are not affected and i get new car papers stating the new approved tyre measure...
I can get this letter, but only in 195/50 R15 measure, not in 185/65R14.
Strange thing, is that the guys at the IPO center, are very strict in "whats on paper issues", but turn blind eyes on bushes, shocks (a shock, only fails an IPO, if it is leaking),suspension geometry, etc...
But if your car papers say one thing, the car must comply with this, or else it fails the IPO... Sad
P.Camilo
Serpent33
PostPosted: Tue Dec 27, 2005 9:19 pm    Post subject: Reply with quote
Hi there. The 145/6 rims have a centre bore slightly smaller (about 0.5 or one mm) and can do with a bit of grinding off. Never force it in. You definately need spacers esp for the rear. It touches the trailing arm. I think I got away with 6mm spacers and still seats in the centre bore. Can't remember exactly but you'll get a very clear picture once you try to fit them in.
Good luck!
