Posted: Sun Aug 26, 2007 7:56 pm Post subject: What is wrong with these photos??? |
Posted: Sun Aug 26, 2007 8:26 pm Post subject: |
What Al said......and the grille is missing  |
Posted: Sun Aug 26, 2007 8:27 pm Post subject: |
Yes Lee... you are a genius! You didn't notice the alternator and radiator are missing too then!?!
Al - I don't understand what you mean mate,
Posted: Sun Aug 26, 2007 8:43 pm Post subject: |
on the cam pulleys, i thought that the left sides should both say L and the right side should both say R. In the pic there is a mixture of L & R on both sides _________________ x2 33 16v
Posted: Sun Aug 26, 2007 8:58 pm Post subject: |
Al... I see. You have a point mate, but I don't think it matters.
The problem is how I bought this car with a broken cambelt, and how that relates to the photos.
Posted: Mon Aug 27, 2007 6:49 am Post subject: |
If you didn't just replace the cambelt, what terrible internal engine carnage could have made the previous owner assume the cambelt had broken?
Belt skipped and threw timing out?
Dropped valve?
Thrown a rod?
Why oh why couldn't you have kept away from 33s, bobbber?  _________________ "Now, all that is left to do ... is wait that something else brokens, to fix up again!" |
Posted: Mon Aug 27, 2007 8:25 am Post subject: |
Bob what are you moaning about you got both belts which are not
broken
On 2nd picture is that chiped tooth on intake cam wheel around 1 o clock area?
Here is image of factory assembled 16v for comparison to all those who haven't seen it in person.
 _________________ Tino Vatavuk
Posted: Mon Aug 27, 2007 8:57 am Post subject: |
So Bob, what's the problem with this motor? Have you tried to start it?
If you find out that the problem is to do with the valves i've still got a few left from the old motor that you can have. |
Posted: Mon Aug 27, 2007 11:04 am Post subject: |
Will it turn over to do a compression check?
Could be a burnt valve, but if just one valve, the car will just run crap with no power, head gasket????
Posted: Mon Aug 27, 2007 3:14 pm Post subject: |
The battery was dead when I got it.... so that's charging up for a compression and running check.
I haven't thought about this before, but will it run ok with the alternator disconnected?
What about the cooling system having no coolant in it?!?!?! For a short while I'm guessing it will be ok!
Funny - years of messing about with cars, and I don't know the answers to these questions....
Also - after about a year break from playing about with them - it's amazing how you can feel like you are wearing boxing gloves when you go back to doing it!!!!
Posted: Mon Aug 27, 2007 4:41 pm Post subject: |
Yeah you can run it with no alternator but it's only going to run as long as the battery lasts so make sure anything you don't need is switched off ie interior fan/ lights etc. I brought a MX3 back from Bath for a friend and the alternator went wrong........travelled for quite a while before every thing started to go Kittens up.
And you'll get away with a short run with no coolant as i did the exact thing when putting my recon engine in I guess it's not recommended but a minute to check the running wont do any harm but make sure you do remember..........just your luck to get it running ok and then forget there's no wet stuff in it! |
Posted: Mon Aug 27, 2007 4:45 pm Post subject: |
Thanks Lee... this is what I expected!
I'll get the bugger running tomorrow and see how it sounds after checking the cam vernier alignments.
Posted: Mon Aug 27, 2007 6:38 pm Post subject: |
Bobbber,
For the compression check you can take out all the plugs and just turn the motor on the starter. It will turn over dead easy cos of no compression on the 3 non checked cylinders.
It will be a bit of a cowson to screw the compression tester in, just like doing the plugs themselves of course.
Posted: Mon Aug 27, 2007 11:24 pm Post subject: |
Paul,
There is no radiator!!! There is no water pump belt!
Rich B Alfa 33
Posted: Tue Aug 28, 2007 6:22 am Post subject: |
well, where do I start - whilst the subject matter is good, your composition needs work. I don't feel you've really captured the atmosphere as well as you could have done.
Maybe a faster shutter speed would have created clearer pictures and how about a filter for some more drama and feeling? |
Posted: Tue Aug 28, 2007 9:53 am Post subject: |
| Rich B wrote: |
Smartass  _________________ Fiat Bravo 165 Sport |
Posted: Tue Aug 28, 2007 11:18 am Post subject: |
Is it running yet? Is it? Is it?
(Not impatient at all me ) |
Rich B Alfa 33
Posted: Tue Aug 28, 2007 1:37 pm Post subject: |
Smartass
Tee hee, sorry mate, couldn't resist it!!!!!!!!! |
Posted: Tue Aug 28, 2007 2:32 pm Post subject: |
Lee,
I'm impatient too! BUT... I have to balance the fine family/car restoration line
Wednesday evenings is my next time available on this special rota... don't worry, I'll keep you informed.
Posted: Wed Sep 05, 2007 2:16 pm Post subject: |
Aux components coming out tonight.... ready for engine removal...
Posted: Wed Sep 05, 2007 4:08 pm Post subject: |
Good luck mate with the removal. Never again for me though!!!  |
Posted: Thu Sep 06, 2007 10:25 am Post subject: |
| lee16v wrote: |
Why not? You'll have this next time (which can also be used to check my progress!) :
http://www.alfa-restoration.co.uk/engineremoval/introduction.html
Any tips greatfully received!
