rsfruitbat Alfa Sprint
Posted: Tue Dec 04, 2007 8:36 am Post subject: 1400 16V rallycar |
Having got my lovely 1400 16V engine back from the builder I am now going to convert the fuel system on the car from carbs to fuel injection .
Can anyone please advise what bore the fuel pipe is for the standard 16V on both the feed from the tank and the return pipe.
Also does anyone know what bore the outlet is on the fuel tank and the fuel pump. I have bought a new 16V fuel pump but it is only 5mm bore which I thought seemed small.
Any comments advice
Regards rsfruitbat  |
Posted: Fri Dec 07, 2007 8:46 am Post subject: fuel injection plumbing |
Hi all,
I have measured my fuel rail pipes and the T's are approx 6mm bore. Looking at it though I am a bit confused. On the front pipe (One that goes behind the alternator) there is just a T piece which I presume is the infeed from the pump / tank. On the back pipe is the fuel pressure regulator. On the bottom of this regulator is a 6mm bore pipe and on the top is a 3mm ? bore pipe. Can someone please advise of what pipe goes where?
Is the 6mm pipe the tank return or vice a versa ? HELP. If so what and where does the 3mm pipe do and go.
rsfruitbat  |
Posted: Fri Dec 07, 2007 1:44 pm Post subject: |
Remember the fuel pressure regulator has a vacuum pipe goes to the inlet manifold (its job it to maintain fuel pressure at a fixed amount over the air pressure in the manifold).
Posted: Fri Dec 07, 2007 1:51 pm Post subject: |
Pipe from fuel tank goes into fuel pulsation damper (the hat with two pipes) and out of the damper into the fuel rail.
OUT of the fuel rail it goes into BOTH SIDES of the fuel pressure regulator, and out the BOTTOM back to the fuel tank. On the TOP of the fuel pressure regulator, like Keith said, is a small bore tube which goes into the inlet manifold. As the suction decreases, i.e. as you open the throttle, this has the effect of increasing the pressure in the fuel rail.
Fuel pressure regulator at the top and pulsation damper at the bottom :
The pipe marked in red on an 8v goes into the intake manifold. On 16v this goes into the intake plenum :
Which clearer shown is this thing I've sat on top the manifold :
Hope that makes sense!
Posted: Fri Dec 07, 2007 2:43 pm Post subject: |
Gentlemen you would go straight too the top of my Xmas card list if I had one.
Bobbber
A "fuel pulsation damper" - have you got a side view picture of it as I dont think I have one. From your description it goes before the T piece at the front of the engine?
Any ideas what happens if you run without it?
I have got an adjustable fuel pressure regulator so I have got the standard one spare if anyone is in need.
Thanks for advice and help
regards rsfruibat |
Posted: Fri Dec 07, 2007 4:41 pm Post subject: |
Yes... if you follow the fuel injection rail, the pipe which comes out of the T piece goes into the fuel pulsation damper. This is the best picture I have of it at the moment :
I'm not sure about the effect of running the injection system without this.
Posted: Fri Dec 07, 2007 5:16 pm Post subject: |
The pulsation damper just takes out the uneven fuel delivery from the pump and provides a fuel delivery with even pressure. I don't think it would do any harm not having it but i don't think the engine would run very even. |
Posted: Thu Apr 17, 2008 1:19 pm Post subject: |
It lives
132bhp at the flywheel at 6900rpm
98bhp at the wheels
100lbs / ft torque between 5500 and 7500rpm
Dave at Mech-repairs thinks cams are a bit wild for a 1400 suggested that 270 deg cams and some head work will produce same or more power at lower rpm and increase torque throughout. Maybe this winter ?
Pleased with result
Thanks to everybody who has helped and supported with this project
rsfruitbat  |
Posted: Thu Apr 17, 2008 1:55 pm Post subject: |
rsfruitbat wrote: |
It lives
98bhp at the wheels
rsfruitbat  |
Fantastic- 132hp from 1400cc
Any pics??
Posted: Thu Apr 17, 2008 5:27 pm Post subject: |
Either drop me your e-mail address or have a look on the alfaowner.com site. I have posted a few thumbnails under various posts. same user name as this site, rsfruitbat
rsfruitbat |
Posted: Tue Apr 22, 2008 5:08 pm Post subject: Rev counter problem |
Anyone got any thoughts on this problem.
On tickover rev counter works fine.
If you rev engine needle works fine up to about 2500 - 3000rpm.
Once you get past this, rev counter needle goes back down hard onto the stop .
Once the revs drop again then needle starts registering again.
If you have had it did you manage to solve it?
rsfruitbat |
Posted: Wed Apr 23, 2008 10:36 pm Post subject: Re: Rev counter problem |
My guess would be some electrical interference somewhere.
