cussid 33 turns over but will not start - checked usual
iglen
PostPosted: Mon Jul 14, 2008 9:56 am    Post subject: cussid 33 turns over but will not start - checked usual Reply with quote
OK
She was running really well then just stopped and dumped me at road side - can get a few revs from cold and full throttle makes a minimal difference - have 2nd 33 for spares so
Have replaced- fuel pump, fuel pump relays, air flow meter, distributor cap and leads, ignition coil, lambda will not budge but have disconnected it to see if that has an effect -it doesn't. Fuel line is not blocked, vacuum circuit ok, all electric connections in engine bay checked and cleaned.
What have I missed?
PostPosted: Mon Jul 14, 2008 10:11 am    Post subject: Reply with quote
Which engine is it? Given you mention an AFM and a cat I presume it is a 16V. Also I assume you have check the cam belts.
PostPosted: Wed Jul 16, 2008 7:47 pm    Post subject: Reply with quote
hows it going?
have you checked for a spark?
have you checked the cas? no cas = no spark
iglen
PostPosted: Fri Jul 18, 2008 1:34 pm    Post subject: Reply with quote
Yes it is a 16v and Keith you are a genius a timing/cam belt has snapped. Forgive my ignorance but is the engine likely to be damaged? - I have a spare one and could make the transplant my summer project.......
PostPosted: Fri Jul 18, 2008 2:27 pm    Post subject: Reply with quote
Yes timing belt and cam belts are the same. There is a very high chance that you will have bent at least 2 valves. Which head is it and from which points to the cams rotate freely, using the "I" and "II" as reference points. It could be possible that the belt snapped with all valves closed, but highly unlikely.
