Jinxed
Oggie
PostPosted: Mon Oct 13, 2008 7:31 pm    Post subject: Jinxed Reply with quote
Just a silly rant about nothing but has anyone suffered the contaminating thread syndrome where as you read a problem with someones 33 and low and behold 2 weeks later your 33 suffers the same issue!?. My electric window motor packed up on Saturday in the down position ahhhh , tested the switch fine, put a meter over the 2 yellow wire and its getting 12volts , anyway taking the car to see our friendly neighbourhood supplier (Paul h) on sat to replace the offending item and perhaps sort some other little issues. Rolling Eyes
PHAT 33
fluffyduff
PostPosted: Mon Oct 13, 2008 10:32 pm    Post subject: Reply with quote
Yep. Was speaking to a friend about upgrading coil & dizzy and mine decides to pack it in. got gradually worse thought it was an advance problem cause it was missing at high revs then missing all the time then sparking irregularly until now its dead completely Rolling Eyes Think the source of the prob may have something to do with the alarm but its not been switched on in years. I don't even have a fob for it so gonna have to bin it.
Getting frustrated with this now Ive not been able to drive it in anger since june. Evil or Very Mad
PostPosted: Tue Oct 14, 2008 12:07 pm    Post subject: Reply with quote
Been there Ian!
Was reading a post a couple of years ago about someone losing the clip on the bottom of the gear linkage...........only three days passed until I was stirring porridge!
The only advise i can give is not to read this forum.......it's bad for your cars health Laughing
Joelomint
PostPosted: Fri Oct 24, 2008 12:32 pm    Post subject: duff dizzy Reply with quote
just a thought, but have you checked the optical trigger and wiring? i've had a couple deteriorate and die, the missfire worsened until it packed up altogether in the way you described...
Oggie
PostPosted: Fri Oct 24, 2008 6:10 pm    Post subject: Reply with quote
Well the problem was not the electric motors fault!, after an hour of thinking its a relay or a short on the cars wiring , it turned out to be a 12v trigger from my 6yr old cobra alarm, when I lock the car my alarm key fob does the central locking and also send 12volts to the window switches to shut the windows, well the alarm was not triggering the window as I think its wiring had shorted on the body work stopping the window motor receiving 12v at all when the switch was pressed. Anyway the window works great and my alarm isn't. Thanks Paul and Big AL for your input last sat Wink
PHAT 33
PostPosted: Fri Oct 24, 2008 7:14 pm    Post subject: Reply with quote
Laughing just wish we started with the alarm
