Steering wheel squeaks
Dr A. 33 1.5IE
PostPosted: Tue Nov 11, 2008 10:24 am    Post subject: Steering wheel squeaks Reply with quote
Dear friends,
My 33 has developed a new habit a few weeks ago. On right turning there are somes squeaks coming from the steering wheel casing just under the instrument panel.
What needs oiling, can you please suggest something to do cos it is a bit annoying?
Thanks in advance
gritsop
PostPosted: Tue Nov 11, 2008 11:29 am    Post subject: Reply with quote
Does this squeak sound if the weather is hot, the car standing for a while under the direct sun? If yes then the horn brush that slips on the steering wheel disk needs to be lubricated.
It is an easy fix by removing the steering column cases and applying a little quantity of grease. It has happened to my 33 quite some times during the last years.
Hope this helps.
Thanassis Gritsopoulos
PostPosted: Wed Nov 12, 2008 7:55 pm    Post subject: Reply with quote
Laughing it will match the squeak you get with the clutch pedal, if your 33 is anything like all 4 i've had Laughing
sorry i couldnt resist
